Power-Aware Regeneration Algorithm in Flex-grid Networks - Network Interfaces Lab, IRT b<>com Accéder directement au contenu
Flex-grid technology increases network links capacity and optical power levels, creating power saturation problem in legacy amplifiers. We demonstrate that optimizing regeneration sites allows reducing the optical power of highly loaded links, avoiding amplifiers saturation over the existing fixed-grid networks.
ECOC_2017_MKANJ.pdf (398.8 Ko) Télécharger le fichier
hal-01543930 , version 1 (21-06-2017)
  • HAL Id : hal-01543930 , version 1
Matthieu Kanj, Esther Le Rouzic, Bernard Cousin. Power-Aware Regeneration Algorithm in Flex-grid Networks. 43rd European Conference on Optical Communication (ECOC 2017), Sep 2017, Gothenburg, Sweden. ⟨hal-01543930⟩
210 Consultations
135 Téléchargements
