The Hotkey Palette: Flexible Contextual Retrieval of Chosen Documents and Windows - CRISTAL-MINT Accéder directement au contenu
We present the Hotkey Palette, a quasi-modal interface enabling quick retrieval of chosen documents and windows by defining and triggering keyboard shortcuts either on the physical keyboard or with an on-screen keyboard. The Hotkey Palette improves on previous work by providing flexible contextualization of shortcuts that leverages document hierarchies, and by merging document and window retrieval in a single interface. The paper describes the design and implementation of the interface and presents novel use cases for document and window management.
p55-aceituno.pdf (1.91 Mo) Télécharger le fichier
hal-01089631 , version 1 (02-12-2014)
hal-01089631 , version 2 (09-01-2015)
Jonathan Aceituno, Nicolas Roussel. The Hotkey Palette: Flexible Contextual Retrieval of Chosen Documents and Windows. IHM'14, 26e conférence francophone sur l'Interaction Homme-Machine, Oct 2014, Lille, France. pp.55-59, ⟨10.1145/2670444.2670452⟩. ⟨hal-01089631v2⟩
253 Consultations
232 Téléchargements
