The Effect of Control-Display Ratio on User Experience in Immersive Virtual Musical Instruments - CRISTAL-MINT Access content directly
Conference Papers Year : 2021
Virtual reality (VR) offers novel possibilities of design choices for Digital Musical Instruments in terms of shapes, sizes, sounds or colours, removing many constraints inherent to physical interfaces. In particular, the size and position of the interface components of Immersive Virtual Musical Instruments (IVMIs) can be freely chosen to elicit large or small hand gestures. In addition, VR allows for the manipulation of what users visually perceive of their actual physical actions, through redirections and changes in Control-Display Ratio (CDR). Visual and gestural amplitudes can therefore be defined separately, potentially affecting the user experience in new ways. In this paper, we investigate the use of CDR to enrich the design with a control over the user perceived fatigue, sense of presence and musical expression. Our findings suggest that the CDR has an impact on the sense of presence, on the perceived difficulty of controlling the sound and on the distance covered by the hand. From these results, we derive a set of insights and guidelines for the design of IVMIs.
c47be986-444a-423c-ab81-83abab65d3e0.pdf (698.51 Ko) Télécharger le fichier
Dates and versions
hal-03265169 , version 1 (19-06-2021)
Identifiers
  • HAL Id : hal-03265169 , version 1
Cite
Vincent Reynaert, Florent Berthaut, Yosra Rekik, Laurent Grisoni. The Effect of Control-Display Ratio on User Experience in Immersive Virtual Musical Instruments. International Conference on New Interfaces for Musical Expression, Jun 2021, Shanghai, China. ⟨hal-03265169⟩
126 View
204 Download
Share
