Open wind tunnel experiments of the DarkO tail-sitter longitudinal stabilization with constant wind - PCGN : Pilotage, Commande, Guidage et Navigation robustes et sûres Accéder directement au contenu
We describe an experimental platform for testing the DarkO tail-sitter drone in an open wind tunnel experiment. The DarkO convertible UAV is developed and 3D printed at the Ecole Nationale de l'Aviation Civile (ENAC), in Toulouse (France). The objective of the experimental platform is to allow testing control laws in a realistic and secure context. We propose a test bench with a single degree of freedom corresponding to the drone pitch axis. We design a linear proportional/integral feedback hovering stabilizer in the presence of constant wind, and we illustrate its effectiveness in stabilizing a hovering position through experimental results.
Open_wind_tunnel_experiments_of_the_DarkO_tail-sitter_longitudinal_stabilization_with_constant_ wind.pdf (1.08 Mo) Télécharger le fichier
hal-04126142 , version 1 (13-06-2023)
Florian Sansou, Fabrice Demourant, Gautier Hattenberger, Thomas Loquen, Luca Zaccarian. Open wind tunnel experiments of the DarkO tail-sitter longitudinal stabilization with constant wind. Automatic control in aerospace, Nov 2022, Mumbai, India. pp.1-6, ⟨10.1016/j.ifacol.2023.03.001⟩. ⟨hal-04126142⟩
48 Consultations
59 Téléchargements
