Conference papers
Implementing Self-Organising Virtual Enterprises Using Social Behaviour Nets
Abstract : Frameworks to support Internet-based virtual enterprises are currently characterised as having fixed process models, fixed meta-data models and a fixed set of users at project inception. This paper proposes the SoBeNet architecture to support a highly dynamic, self-organised, Internet-based approach based on social interaction. The architecture is based on a multi-agent approach, Internet communication being achieved through RSS feeds. RSS conveys state changes by carrying data defined in a common ontology. Each agent assesses state changes using a virtual sensor by calculating the semantic distance between the change and its own interests. Each agent also contains a behaviour network which uses an activation spreading paradigm to react to a combination of its own goals and state changes. The SoBeNet test-bed is based on the Java JADE environment.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01055984
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, August 25, 2014 - 5:14:16 PM
Last modification on : Wednesday, November 25, 2020 - 5:14:02 PM
Long-term archiving on: : Tuesday, April 11, 2017 - 7:55:39 PM
File
pro31.pdf
Identifiers
Citation
Ping Jiang, Quentin Mair, Mingwei Yuan. Implementing Self-Organising Virtual Enterprises Using Social Behaviour Nets. 11th IFIP WG 5.5 Working Conference on Virtual Enterprises (PRO-VE), Oct 2010, Saint-Etienne, France. pp.259-266, ⟨10.1007/978-3-642-15961-9_31⟩. ⟨hal-01055984⟩
Share
Metrics
Les métriques sont temporairement indisponibles
