Full Text Documents
Chargement de la page
Search
Table of Contents
System Modeling and Optimization
Dietmar Hömberg, Fredi Tröltzsch (Eds.)
Front Matter
Plenary Talks
Second Order Conditions for L2 Local Optimality in PDE Control
Eduardo Casas
1-12
Quadratic ODE and PDE Models of Drug Release Kinetics from Biodegradable Polymers
Michel Delfour, André Garon
13-24
A Critical Note on Empirical (Sample Average, Monte Carlo) Approximation of Solutions to Chance Constrained Programs
René Henrion
25-37
Convergence Rates for the Iteratively Regularized Landweber Iteration in Banach Space
Barbara Kaltenbacher
38-48
Control of Distributed Parameter Systems
Weak Compactness in the Space of Operator Valued Measures and Optimal Control
Nasiruddin Ahmed
49-58
Adaptive Methods for Control Problems with Finite-Dimensional Control Space
Saheed Akindeinde, Daniel Wachsmuth
59-69
Dynamic Contact Problem for Viscoelastic von Kármán-Donnell Shells
Igor Bock, Jiří Jarušek
70-75
On Existence, Uniqueness, and Convergence of Optimal Control Problems Governed by Parabolic Variational Inequalities
Mahdi Boukrouche, Domingo Tarzia
76-84
A Note on Linear Differential Variational Inequalities in Hilbert Space
Joachim Gwinner
85-91
Model Order Reduction for Networks of ODE and PDE Systems
Michael Hinze, Ulrich Matthes
92-101
Path-Planning with Collision Avoidance in Automotive Industry
Chantal Landry, Matthias Gerdts, René Henrion, Dietmar Hömberg
102-111
Regularized Extremal Shift in Problems of Stable Control
Vyacheslav Maksimov
112-121
New Necessary Conditions for Optimal Control Problems in Discontinuous Dynamic Systems
Ekaterina Kostina, Olga Kostyukova, Werner Schmidt
122-135
Numerical Methods for the Optimal Control of Scalar Conservation Laws
Sonja Steffensen, Michael Herty, Lorenzo Pareschi
136-144
Necessary Conditions for Convergence Rates of Regularizations of Optimal Control Problems
Daniel Wachsmuth, Gerd Wachsmuth
145-154
Stochastic Optimization and Control
Robustness Analysis of Stochastic Programs with Joint Probabilistic Constraints
Jitka Dupačová
155-164
State Estimation for Control Systems with a Multiplicative Uncertainty through Polyhedral Techniques
Elena Kostousova
165-176
An Algorithm for Two-Stage Stochastic Quadratic Problems
Eugenio Mijangos
177-187
Risk Minimizing Strategies for Tracking a Stochastic Target
Andrzej Palczewski
188-196
Harvesting in Stochastic Environments: Optimal Policies in a Relaxed Model
Richard Stockbridge, Chao Zhu
197-206
Estimation of Loan Portfolio Risk on the Basis of Markov Chain Model
Nikolay Timofeev, Galina Timofeeva
207-216
Stabilization, Feedback, and Model Predictive Control
MPC/LQG for Infinite-Dimensional Systems Using Time-Invariant Linearizations
Peter Benner, Sabine Hein
217-224
On an Algorithm for Dynamic Reconstruction in Systems with Delay in Control
Marina Blizorukova
225-234
Computation of Value Functions in Nonlinear Differential Games with State Constraints
Nikolai Botkin, Karl-Heinz Hoffmann, Natalie Mayer, Varvara Turova
235-244
Geometric Conditions for Regularity of Viscosity Solution to the Simplest Hamilton-Jacobi Equation
Vladimir Goncharov, Fátima Pereira
245-254
Stabilization of the Gas Flow in Star-Shaped Networks by Feedback Controls with Varying Delay
Martin Gugat, Markus Dick, Günter Leugering
255-265
Real-Time Nonlinear Model Predictive Control of a Glass Forming Process Using a Finite Element Model
Janko Petereit, Thomas Bernard
266-275
Exponential Stability of the System of Transmission of the Wave Equation with a Delay Term in the Boundary Feedback
Salah-Eddine Rebiai
276-285
Nonlinear Stabilizers in Optimal Control Problems with Infinite Time Horizon
Alexander Tarasyev, Anastasia Usova
286-295
Combined Feedforward/Model Predictive Tracking Control Design for Nonlinear Diffusion-Convection-Reaction-Systems
Tilman Utz, Knut Graichen, Andreas Kugi
296-305
Temporal and One-Step Stabilizability and Detectability of Time-Varying Discrete-Time Linear Systems
L. Willigenburg, Willem Koning
306-317
Flow Control
Optimal Control of Unsteady Flows Using a Discrete and a Continuous Adjoint Approach
Angelo Carnarius, Frank Thiele, Emre Özkaya, Anil Nemili, Nicolas Gauger
318-327
Well-Posedness and Long Time Behavior for a Class of Fluid-Plate Interaction Models
Igor Chueshov, Iryna Ryzhkova
328-337
On the Normal Semilinear Parabolic Equations Corresponding to 3D Navier-Stokes System
Andrei Fursikov
338-347
A Nonlinear Model Predictive Concept for Control of Two-Phase Flows Governed by the Cahn-Hilliard Navier-Stokes System
Michael Hinze, Christian Kahle
348-357
Embedding Domain Technique for a Fluid-Structure Interaction Problem
Cornel Murea, Andrei Halanay
358-367
Shape and Structural Optimization
Note on Level Set Functions
Piotr Fulmański, Alicja Miniak-Górecka
368-377
Fixed Domain Algorithms in Shape Optimization for Stationary Navier-Stokes Equations
Andrei Halanay, Cornel Murea
378-386
An Electrohydrodynamic Equilibrium Shape Problem for Polymer Electrolyte Membranes in Fuel Cells
Sven-Joachim Kimmerle, Peter Berg, Arian Novruzi
387-396
Reduction Strategies for Shape Dependent Inverse Problems in Haemodynamics
Toni Lassila, Andrea Manzoni, Gianluigi Rozza
397-406
Structural Optimization of Variational Inequalities Using Piecewise Constant Level Set Method
Andrzej Myśliński
407-416
Numerical Shape Optimization via Dynamic Programming
Jan Pustelnik
417-426
Shape Sensitivity Analysis of Incompressible Non-Newtonian Fluids
Jan Sokołowski, Jan Stebel
427-436
Finite Element Discretization in Shape Optimization Problems for the Stationary Navier-Stokes Equation
Dan Tiba
437-444
Strong Shape Derivative for the Wave Equation with Neumann Boundary Condition
Jean-Paul Zolésio, Lorena Bociu
445-460
Applications and Control of Lumped Parameter Systems
The Exact l1 Penalty Function Method for Constrained Nonsmooth Invex Optimization Problems
Tadeusz Antczak
461-470
The Minimum Energy Building Temperature Control
Marek Długosz
471-480
Introducing Periodic Parameters in a Marine Ecosystem Model Using Discrete Linear Quadratic Control
Mustapha Jarbi, Thomas Slawig, Andreas Oschlies
481-490
Avoidance Trajectories Using Reachable Sets and Parametric Sensitivity Analysis
Matthias Gerdts, Ilaria Xausa
491-500
Theoretical Analysis and Optimization of Nonlinear ODE Systems for Marine Ecosystem Models
Anna Heinle, Thomas Slawig
501-510
Solving Electric Market Quadratic Problems by Branch and Fix Coordination Methods
F. Heredia, Cristina Corchero, Eugenio Mijangos
511-520
Asymptotic Behavior of Nonlinear Transmission Plate Problem
Mykhailo Potomkin
521-527
p-th Order Optimality Conditions for Singular Lagrange Problem in Calculus of Variations. Elements of p-Regularity Theory
Agnieszka Prusińska, Ewa Szczepanik, Alexey Tret’yakov
528-537
Mathematical and Implementation Challenges Associated with Testing of the Dynamical Systems
Pawel Skruch
538-546
Numerical Parameters Estimation in Models of Pollutant Transport with Chemical Reaction
Fabiana Zama, Roberta Ciavarelli, Dario Frascari, Davide Pinelli
547-556
N Dimensional Crowd Motion
Jean-Paul Zolésio, Paola Goatin
557-566
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
