Conference papers
Reducing the Time Required for Hashing Operations
Abstract : Due to the increasingly massive amounts of data that need to be analyzed in digital forensic investigations, it is necessary to automatically recognize suspect files and filter out non-relevant files. To achieve this goal, digital forensic practitioners employ hashing algorithms to classify files into known-good, known-bad and unknown files. However, a typical personal computer may store hundreds of thousands of files and the task becomes extremely time-consuming. This paper attempts to address the problem using a framework that speeds up processing by using multiple threads. Unlike a typical multithreading approach, where the hashing algorithm is performed by multiple threads, the proposed framework incorporates a dedicated prefetcher thread that reads files from a device. Experimental results demonstrate a runtime efficiency of nearly 40% over single threading.
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01460624
Contributor : Hal Ifip <>
Submitted on : Tuesday, February 7, 2017 - 5:26:31 PM
Last modification on : Thursday, March 5, 2020 - 4:46:40 PM
Document(s) archivé(s) le : Monday, May 8, 2017 - 3:03:13 PM
File
978-3-642-41148-9_7_Chapter.pd...
Identifiers
Citation
Frank Breitinger, Kaloyan Petrov. Reducing the Time Required for Hashing Operations. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.101-117, ⟨10.1007/978-3-642-41148-9_7⟩. ⟨hal-01460624⟩
Share
Metrics
Record views
225
Files downloads
508
