Six Degrees of Freedom Implicit Haptic Rendering
Abstract : This paper introduces a six degrees of freedom haptic rendering scheme based on an implicit support plane mapping representation of the object geometries. The proposed scheme enables, under specific assumptions, the analytical reconstruction of the rigid 3D object’s surface, using the equations of the support planes and their respective distance map. As a direct consequence, the problem of calculating the force feedback can be analytically solved using only information about the 3D object’s spatial transformation and position of the haptic probe. Several haptic effects are derived by the proposed mesh-free haptic rendering formulation. Experimental evaluation and computational complexity analysis demonstrates that the proposed approach can reduce significantly the computational cost when compared to existing methods.
Document type :
Conference papers
Complete list of metadatas
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01391357
Contributor : Hal Ifip <>
Submitted on : Thursday, November 3, 2016 - 11:06:54 AM
Last modification on : Tuesday, December 26, 2017 - 4:38:01 PM
Long-term archiving on : Saturday, February 4, 2017 - 1:33:18 PM
File
978-3-662-44654-6_54_Chapter.p...
Identifiers
Citation
Konstantinos Moustakas. Six Degrees of Freedom Implicit Haptic Rendering. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.546-555, ⟨10.1007/978-3-662-44654-6_54⟩. ⟨hal-01391357⟩
Share
Metrics
Record views
91
Files downloads
117
