Conference papers
Combining Model Refinement and Test Generation for Conformance Testing of the IEEE PHD Protocol Using Abstract State Machines
Abstract : In this paper we propose a new approach to conformance testing based on Abstract State Machine (ASM) model refinement. It consists in generating test sequences from ASM models and checking the conformance between code and models in multiple iterations. This process is applied at different models, starting from the more abstract model to the one that is very close to the code. The process consists of the following steps: (1) model the system as an Abstract State Machine, (2) generate test sequences based on the ASM model, (3) compute the code coverage using generated tests, (4) if the coverage is low refine the Abstract State Machine and return to step 2. We have applied the proposed approach to Antidote, an open-source implementation of IEEE 11073-20601 Personal Health Device (PHD) protocol which allows personal healthcare devices to exchange data with other devices such as small computers and smartphones.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-02526351
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, March 31, 2020 - 3:14:01 PM
Last modification on : Tuesday, March 31, 2020 - 3:58:12 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2022-01-01
Please log in to resquest access to the document
Identifiers
Citation
Andrea Bombarda, Silvia Bonfanti, Angelo Gargantini, Marco Radavelli, Feng Duan, et al.. Combining Model Refinement and Test Generation for Conformance Testing of the IEEE PHD Protocol Using Abstract State Machines. 31th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2019, Paris, France. pp.67-85, ⟨10.1007/978-3-030-31280-0_5⟩. ⟨hal-02526351⟩
Share
Metrics
Record views
65
