Conference papers
Specification of Embedded Control Systems Behaviour Using Actor Interface Automata
Abstract : Distributed Timed Multitasking (DTM) is a model of computation describing the operation of hard real-time embedded control systems. With this model, an application is conceived as a network of distributed embedded actors that communicate with one another by exchanging labeled messages (signals), independent of their physical allocation. Input and output signals are exchanged with the controlled plant at precisely specified time instants, which provides for a constant delay from sampling to actuation and the elimination of I/O jitter. The paper presents an operational specification of DTM in terms of actor interface automata, whereby a distributed control system is modeled as a set of communicating interface automata executing distributed transactions. The above modeling technique has implications for system design, since interface automata can be used as design models that can be implemented as application or operating system components. It has also implications for system analysis, since actor interface automata are essentially timed automata that can be used as analysis models in model checking tools and simulation environments.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01055388
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, August 12, 2014 - 4:04:20 PM
Last modification on : Thursday, March 5, 2020 - 5:40:49 PM
Long-term archiving on: : Wednesday, November 26, 2014 - 11:10:14 PM
File
SEUS_2010_Paper_15_-_Actor_Int...
Identifiers
Citation
Christo Angelov, Feng Zhou, Krzysztof Sierszecki. Specification of Embedded Control Systems Behaviour Using Actor Interface Automata. 8th IFIP WG 10.2 International Workshop on Software Technologies for Embedded and Ubiquitous Systems (SEUS), Oct 2010, Waidhofen/Ybbs, Austria. pp.167-178, ⟨10.1007/978-3-642-16256-5_17⟩. ⟨hal-01055388⟩
Share
Metrics
Record views
486
Files downloads
658
