Combining Goal-Oriented and Problem-Oriented Requirements Engineering Methods
Abstract : Several requirements engineering methods exist that differ in their abstraction level and in their view on the system-to-be. Two fundamentally different classes of requirements engineering methods are goal- and problem-based methods. Goal-based methods analyze the goals of stakeholders towards the system-to-be. Problem-based methods focus on decomposing the development problem into simple sub-problems. Goal-based methods use a higher abstraction level that consider only the parts of a system that are relevant for a goal and provide the means to analyze and solve goal conflicts. Problem-based methods use a lower abstraction level that describes the entire system-to-be. A combination of these methods enables a seamless software development, which considers stakeholders’ goals and a comprehensive view on the system-to-be at the requirements level. We propose a requirements engineering method that combines the goal-based method SI* and the problem-based method Problem Frames. We propose to analyze the issues between different goals of stakeholders first using the SI* method. Our method provides the means to use the resulting SI* models as input for the problem frame method. These Problem Frame models can be refined into architectures using existing research. Thus, we provide a combined requirements engineering method that considers all stakeholder views and provides a detailed system specification. We illustrate our method using an E-Health example.
Complete list of metadatas
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01506766
Contributor : Hal Ifip <>
Submitted on : Wednesday, April 12, 2017 - 11:19:00 AM
Last modification on : Thursday, April 13, 2017 - 1:06:47 AM
Long-term archiving on : Thursday, July 13, 2017 - 12:40:16 PM
File
978-3-642-40511-2_13_Chapter.p...
Identifiers
  • HAL Id : hal-01506766, version 1
Citation
Kristian Beckers, Stephan Faßbender, Maritta Heisel, Federica Paci. Combining Goal-Oriented and Problem-Oriented Requirements Engineering Methods. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.178-194. ⟨hal-01506766⟩
Share
Metrics
Record views
185
Files downloads
320
