An end-to-end data-driven optimisation framework for constrained trajectories - Inria CWI Access content directly
Journal Articles Data-Centric Engineering Year : 2022
Many real-world problems require to optimise trajectories under constraints. Classical approaches are based on optimal control methods but require an exact knowledge of the underlying dynamics, which could be challenging or even out of reach. In this paper, we leverage data-driven approaches to design a new end-to-end framework which is dynamics-free for optimised and realistic trajectories. We first decompose the trajectories on function basis, trading the initial infinite dimension problem on a multivariate functional space for a parameter optimisation problem. A maximum \emph{a posteriori} approach which incorporates information from data is used to obtain a new optimisation problem which is regularised. The penalised term focuses the search on a region centered on data and includes estimated linear constraints in the problem. We apply our data-driven approach to two settings in aeronautics and sailing routes optimisation, yielding commanding results. The developed approach has been implemented in the Python library PyRotor.
2011.11820.pdf (1.01 Mo) Télécharger le fichier
Dates and versions
hal-03024720 , version 1 (25-11-2020)
Identifiers
Cite
Florent Dewez, Benjamin Guedj, Arthur Talpaert, Vincent Vandewalle. An end-to-end data-driven optimisation framework for constrained trajectories. Data-Centric Engineering, 2022, 3, pp.e6. ⟨10.1017/dce.2022.6⟩. ⟨hal-03024720⟩
78 View
83 Download
Share
