Zermelo navigation on the sphere with revolution metrics - Calcul Intensif, Simulation, Optimisation Access content directly
Book Sections Year : 2024
In this article motivated by physical applications, the Zermelo navigation problem on the two-dimensional sphere with a revolution metric is analyzed within the framework of minimal time optimal control. The Pontryagin maximum principle is used to compute extremal curves and a neat geometric frame is introduced using the Carathéodory-Zermelo-Goh transformation. Assuming that the current is of revolution, the geodesics are sorted according to a Morse-Reeb classification. We then illustrate the relevance of this classification using various examples from physics: the Lindblad equation in quantum control, the averaged Kepler case in space mechanics and the Landau-Lifshitz equation in ferromagnetism.
BCPT_Zermelo-HAL.pdf (7.52 Mo) Télécharger le fichier
BCPT_Zermelo-HAL (1).pdf (7.52 Mo) Télécharger le fichier
Dates and versions
hal-04433828 , version 1 (02-02-2024)
Attribution - NoDerivatives
Identifiers
  • HAL Id : hal-04433828 , version 1
Cite
Bernard Bonnard, Olivier Cots, Yannick Privat, Emmanuel Trélat. Zermelo navigation on the sphere with revolution metrics. IVAN KUPKA LEGACY: A Tour Through Controlled Dynamics, 12, pp.35--66, 2024, AIMS Applied Math Books - Special issue in honor of I. Kupka, ISBN-10: 1-60133-026-X ISBN-13: 978-1-60133-026-0. ⟨hal-04433828⟩
125 View
54 Download
Share
