Outlier Detection at the Parcel-level in Wheat and Rapeseed Crops Using Multispectral and SAR Time Series - Computational Imaging and Vision Accéder directement au contenu
Article Dans Une Revue Remote Sensing Année : 2021
Mohanad Albughdadi
Sylvie Duthoit
  • Fonction : Auteur
  • PersonId : 1019552
Denis Kouamé
Guillaume Rieu
  • Fonction : Auteur
  • PersonId : 1092665
Jean-Yves Tourneret
This paper studies the detection of anomalous crop development at the parcel-level based on an unsupervised outlier detection technique. The experimental validation is conducted on rapeseed and wheat parcels located in Beauce (France). The proposed methodology consists of four sequential steps: (1) preprocessing of synthetic aperture radar (SAR) and multispectral images acquired using Sentinel-1 and Sentinel-2 satellites, (2) extraction of SAR and multispectral pixel-level features, (3) computation of parcel-level features using zonal statistics and (4) outlier detection. The different types of anomalies that can affect the studied crops are analyzed and described. The different factors that can influence the outlier detection results are investigated with a particular attention devoted to the synergy between Sentinel-1 and Sentinel-2 data. Overall, the best performance is obtained when using jointly a selection of Sentinel-1 and Sentinel-2 features with the isolation forest algorithm. The selected features are co-polarized (VV) and cross-polarized (VH) backscattering coefficients for Sentinel-1 and five Vegetation Indexes for Sentinel-2 (among us, the Normalized Difference Vegetation Index and two variants of the Normalized Difference Water). When using these features with an outlier ratio of 10%, the percentage of detected true positives (i.e., crop anomalies) is equal to 94.1% for rapeseed parcels and 95.5% for wheat parcels.
remotesensing-13-00956.pdf (2.37 Mo) Télécharger le fichier
final_version_supplement_paper_MDPI_RS_crop_AD.pdf (1.3 Mo) Télécharger le fichier
hal-02546260 , version 1 (17-04-2020)
hal-02546260 , version 2 (14-09-2020)
hal-02546260 , version 3 (05-03-2021)
Paternité
Florian Mouret, Mohanad Albughdadi, Sylvie Duthoit, Denis Kouamé, Guillaume Rieu, et al.. Outlier Detection at the Parcel-level in Wheat and Rapeseed Crops Using Multispectral and SAR Time Series. Remote Sensing, 2021, 13 (5), pp.956. ⟨10.3390/rs13050956⟩. ⟨hal-02546260v3⟩
434 Consultations
679 Téléchargements
