A Re-optimization approach for the Dynamic Capacitated Vehicle Routing Problem for Flash Flood Victim's Relief Operations - Système d’Exploitation, systèmes Répartis, de l’Intergiciel à l’Architecture Accéder directement au contenu
The purpose of this work is to solve the Dynamic vehicle Routing Problem applied to Victim relief operations for flash floods. This work compare the performances of different heruistics thanks to an evaluation through a simulator.
Presentation_ROADEF_v2.pdf (175 Ko) Télécharger le fichier
hal-03596161 , version 1 (03-03-2022)
  • HAL Id : hal-03596161 , version 1
Florent Dubois, Paul Renaud-Goud, Patricia Stolf. A Re-optimization approach for the Dynamic Capacitated Vehicle Routing Problem for Flash Flood Victim's Relief Operations. 23ème Congrès annuel de la Société Française de Recherche Opérationnelle et d'Aide à la Décision (ROADEF 2022), INSA Lyon; Université de Lyon, Feb 2022, Villeurbanne - Lyon, France. ⟨hal-03596161⟩
136 Consultations
35 Téléchargements
