Diffusion-approximation for a kinetic equation with perturbed velocity redistribution process - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We derive the hydrodynamic limit of a kinetic equation with a stochastic, short range perturbation of the velocity operator. Under some mixing hypotheses on the stochastic perturbation, we establish a diffusion-approximation result: the limit we obtain is a parabolic stochastic partial differential equation on the macroscopic parameter, the density here.
CaillerieVovelleDA.pdf (400.79 Ko) Télécharger le fichier
hal-01672879 , version 1 (27-12-2017)
hal-01672879 , version 2 (29-09-2020)
N Caillerie, J Vovelle. Diffusion-approximation for a kinetic equation with perturbed velocity redistribution process. 2017. ⟨hal-01672879v1⟩
228 Consultations
149 Téléchargements
