Diffusion-approximation for a kinetic equation with perturbed velocity redistribution process - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Nils Caillerie
  • Fonction : Auteur
  • PersonId : 976939
  • IdRef : 204091365
We derive the hydrodynamic limit of a kinetic equation with a stochastic, short range perturbation of the velocity operator. Under some mixing hypotheses on the stochastic perturbation, we establish a diffusion-approximation result: the limit we obtain is a parabolic stochastic partial differential equation on the macroscopic parameter, the density here.
CaillerieVovelleMA.pdf (562.26 Ko) Télécharger le fichier
hal-01672879 , version 1 (27-12-2017)
hal-01672879 , version 2 (29-09-2020)
Nils Caillerie, Julien Vovelle. Diffusion-approximation for a kinetic equation with perturbed velocity redistribution process. 2020. ⟨hal-01672879v2⟩
226 Consultations
146 Téléchargements
