On the top-dimensional ℓ^2 -Betti numbers - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Sur les nombres de Betti ℓ^2 en dimension maximale
Camille Noûs
The purpose of this note is to introduce a trick which relates the (non)-vanishing of the top-dimensional ℓ 2-Betti numbers of actions with that of sub-actions. We provide three different types of applications: we prove that the ℓ 2-Betti numbers of Aut(Fn) and Out(Fn) (and of their Torelli subgroups) do not vanish in degree equal to their virtual cohomological dimension, we prove that the subgroups of the 3-manifold groups have vanishing ℓ 2-Betti numbers in degree 3 and 2 and we prove for instance that F_2^d × Z has ergodic dimension d + 1.
Top-dim-L2-4.pdf (254.67 Ko) Télécharger le fichier
hal-02273797 , version 1 (29-08-2019)
hal-02273797 , version 2 (11-06-2020)
hal-02273797 , version 3 (26-06-2020)
hal-02273797 , version 4 (27-06-2022)
Damien Gaboriau, Camille Noûs. On the top-dimensional ℓ^2 -Betti numbers. 2019. ⟨hal-02273797v1⟩
197 Consultations
407 Téléchargements
