1,3‐Acetonedicarboxylic Acid as a Simple Stimulus for Reversible Time‐Controlled pH Modulation - Labex Arcane Accéder directement au contenu
Article Dans Une Revue ChemSystemsChem Année : 2024
Implementation of new activated carboxylic acids is crucial to switch reversibly chemical systems over time in a safer manner. By applying cheap 1,3‐acetonedicarboxylic acid, the pH of aqueous solutions can be decreased before autonomously evolving over time back again to a higher value upon diacid decarboxylation. This decarboxylation can be catalysed by different species such as simple amines or simple metals such as iron and copper salts. This process generates 2 molecules of CO 2 and acetone as single waste, considerably decreasing the toxicity associated with such activated acids. The potential of this weak diacid was confirmed by reversibly disrupting a strong gel upon diacid addition and opens the way to the application in complex chemically fuelled systems.
manuscript.pdf (731.48 Ko) Télécharger le fichier
hal-04426388 , version 1 (30-01-2024)
Vincent Verdoot, Adrien Quintard. 1,3‐Acetonedicarboxylic Acid as a Simple Stimulus for Reversible Time‐Controlled pH Modulation. ChemSystemsChem, 2024, 6 (1), pp.e202300037. ⟨10.1002/syst.202300037⟩. ⟨hal-04426388⟩
20 Consultations
1 Téléchargements
