Service Placement in Fog Computing Using Constraint Programming - CORSE - Computer Optimization and Run-time SystEms Accéder directement au contenu
SCC_2019.pdf (3.45 Mo) Télécharger le fichier
hal-02108806 , version 1 (24-04-2019)
Farah Ait Salaht, Frédéric Desprez, Adrien Lebre, Charles Prud'Homme, Mohamed Abderrahim. Service Placement in Fog Computing Using Constraint Programming. SCC 2019 : IEEE International Conference on Services Computing, Jul 2019, Milan, Italy. pp.19-27, ⟨10.1109/SCC.2019.00017⟩. ⟨hal-02108806⟩
364 Consultations
606 Téléchargements
