Model Checking and Co-simulation of a Dynamic Task Dispatcher Circuit using CADP - CONVECS Accéder directement au contenu
The complexity of multiprocessor architectures for mobile multi-media applications renders their validation challenging. In addition, to provide the necessary flexibility, a part of the functionality is realized by software. Thus, a formal model has to take into account both hardware and software. In this paper we report on the use of LOTOS NT and CADP for the formal modeling and analysis of the DTD (Dynamic Task Dispatcher), a complex hardware block of an industrial hardware architecture developed by STMicroelectronics. Using LOTOS NT facilitated exploration of alternative design choices and increased the confidence in the DTD, by, on the one hand, automatic analysis of formal models easily understood by the architect of the DTD, and, on the other hand, co-simulation of the formal model with the implementation used for synthesis.
Lantreibecq-Serwe-11.pdf (192.36 Ko) Télécharger le fichier
hal-00642029 , version 1 (17-11-2011)
  • HAL Id : hal-00642029 , version 1
Etienne Lantreibecq, Wendelin Serwe. Model Checking and Co-simulation of a Dynamic Task Dispatcher Circuit using CADP. Formal Methods for Industrial Critical Systems, 2011, Trento, Italy. ⟨hal-00642029⟩
228 Consultations
137 Téléchargements
