Visualizing Information on Watch Faces: A Survey with Smartwatch Users - Interacting with Large Data Accéder directement au contenu
Alaul Islam
Anastasia Bezerianos
Tanja Blascheck
Petra Isenberg
People increasingly wear smartwatches that can track a wide variety of data. However, it is currently unknown which data people consume and how it is visualized. To better ground research on smartwatch visualization, it is important to understand the current use of these representation types on smartwatches, and to identify missed visualization opportunities. We present the findings of a survey with 237 smartwatch wearers, and assess the types of data and representations commonly displayed on watch faces. We found a predominant display of health & fitness data, with icons accompanied by text being the most frequent representation type. Combining these results with a further analysis of online searches of watch faces and the data tracked on smartwatches that are not commonly visualized, we discuss opportunities for visualization research. Supplementary material is available at https://osf.io/nwy2r/.
gtwyrgpjfthrchyttgsxdrjrvhccyqvy.pdf (18.18 Mo) Télécharger le fichier
Format : Figure, Image
hal-03005319 , version 1 (14-11-2020)
hal-03005319 , version 2 (18-11-2020)
Alaul Islam, Anastasia Bezerianos, Bongshin Lee, Tanja Blascheck, Petra Isenberg. Visualizing Information on Watch Faces: A Survey with Smartwatch Users. Short Papers of the IEEE Conference on Visualization (VIS), Oct 2020, Virtual Conference, United States. ⟨10.1109/VIS47514.2020.00038⟩. ⟨hal-03005319v1⟩
357 Consultations
262 Téléchargements
