Fully Trainable and Interpretable Non-Local Sparse Models for Image Restoration - PaRis AI Research InstitutE Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Non-local self-similarity and sparsity principles have proven to be powerful priors for natural image modeling. We propose a novel differentiable relaxation of joint sparsity that exploits both principles and leads to a general framework for image restoration which is (1) trainable end to end, (2) fully interpretable, and (3) much more compact than competing deep learning architectures. We apply this approach to denoising, jpeg deblocking, and demosaicking, and show that, with as few as 100K parameters, its performance on several standard benchmarks is on par or better than state-of-the-art methods that may have an order of magnitude or more parameters.
main.pdf (5.66 Mo) Télécharger le fichier
hal-02414291 , version 1 (16-12-2019)
hal-02414291 , version 2 (24-03-2020)
hal-02414291 , version 3 (24-07-2020)
  • HAL Id : hal-02414291 , version 2
Bruno Lecouat, Jean Ponce, Julien Mairal. Fully Trainable and Interpretable Non-Local Sparse Models for Image Restoration. 2020. ⟨hal-02414291v2⟩
497 Consultations
656 Téléchargements
