Fuzzy Fault-Tolerant Predefined-Time Control for Switched Systems: A Singularity-Free Method - Réseau de recherche en Théorie des Systèmes Distribués, Modélisation, Analyse et Contrôle des Systèmes Access content directly
Journal Articles IEEE Transactions on Fuzzy Systems Year : 2024
The subject of this study is fuzzy predefined-time control for a class of switched nonlinear systems with multiple faults. In comparison to existing research on predefined-time control, this study delves into the realm of switched nonlinear systems, encompassing switched linear sensor faults and switched non-affine faults. The difficulty in the controller design lies in following the backstepping technique, as taking the derivative of fractional power virtual control laws would trigger singularity issues at equilibrium states or coordinate transformation origins. The study utilizes the unique characteristics of switching and fuzzy logic systems to introduce a continuous piecewise predefined-time controller with a fault-tolerant compensation mechanism to avoid singularity problems. By adjusting a predefined parameter in the developed controller, the system could achieve the objectives of adaptive stability and adaptive tracking within a predefined time, as desired by the user. Moreover, the application of the proposed algorithm to practical systems is presented.
Cui2024.pdf (563.53 Ko) Télécharger le fichier
Dates and versions
hal-04243143 , version 1 (02-05-2024)
Identifiers
Cite
Di Cui, Mohammed Chadli, Zhengrong Xiang. Fuzzy Fault-Tolerant Predefined-Time Control for Switched Systems: A Singularity-Free Method. IEEE Transactions on Fuzzy Systems, 2024, 32 (3), pp.1223--1232. ⟨10.1109/TFUZZ.2023.3321688⟩. ⟨hal-04243143⟩
63 View
0 Download
Share
