Scattering below critical energy for the radial 4D Yang-Mills equation and for the 2D corotational wave map system - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Physics Année : 2008
We describe the asymptotic behavior as time goes to infinity of solutions of the 2 dimensional corotational wave map system and of solutions to the 4 dimensional, radially symmetric Yang-Mills equation, in the critical energy space, with data of energy smaller than or equal to a harmonic map of minimal energy. An alternative holds: either the data is the harmonic map and the solution is constant in time, or the solution scatters in infinite time.
wmscattering.pdf (345.53 Ko) Télécharger le fichier
hal-00221387 , version 1 (14-02-2020)
Raphaël Côte, Carlos Kenig, Frank Merle. Scattering below critical energy for the radial 4D Yang-Mills equation and for the 2D corotational wave map system. Communications in Mathematical Physics, 2008, 284 (1), pp.203-225. ⟨10.1007/s00220-008-0604-4⟩. ⟨hal-00221387⟩
145 Consultations
47 Téléchargements
