Characterization of large energy solutions of the equivariant wave map problem: II - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue American Journal of Mathematics Année : 2015
We consider 1-equivariant wave maps from 1+2 dimensions to the 2-sphere of finite energy. We establish a classification of all degree 1 global solutions whose energies are less than three times the energy of the harmonic map Q. In particular, for each global energy solution of topological degree 1, we show that the solution asymptotically decouples into a rescaled harmonic map plus a radiation term. Together with our companion article, where we consider the case of finite-time blow up, this gives a characterization of all 1-equivariant, degree 1 wave maps in the energy regime [E(Q), 3E(Q)).
CKLS2-new.pdf (404.21 Ko) Télécharger le fichier
hal-00832752 , version 1 (14-02-2020)
Raphaël Côte, Carlos Kenig, Andrew Lawrie, Wilhelm Schlag. Characterization of large energy solutions of the equivariant wave map problem: II. American Journal of Mathematics, 2015, 137 (1), pp.209-250. ⟨10.1353/ajm.2015.0003⟩. ⟨hal-00832752⟩
137 Consultations
31 Téléchargements
