Multi-solitons for nonlinear Klein-Gordon equations - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Forum of Mathematics, Sigma Année : 2014
In this paper we consider the existence of multi-soliton structures for the nonlinear Klein-Gordon equation (NLKG) in R^{1+d}. We prove that, independently of the unstable character of (NLKG) solitons, it is possible to construct a N-soliton family of solutions to (NLKG), of dimension 2N, globally well-defined in the energy space H^1 \times L^2 for all large positive times. The method of proof involves the generalization of previous works on supercritical NLS and gKdV equations by Martel, Merle and the first author to the wave case, where we replace the unstable mode associated to the linear NLKG operator by two generalized directions that are controlled without appealing to modulation theory. As a byproduct, we generalize the linear theory described in Grillakis-Shatah-Strauss and Duyckaerts-Merle to the case of boosted solitons, and provide new solutions to be studied using the recent Nakanishi- Schlag theory.
kg_nsol_final.pdf (516.59 Ko) Télécharger le fichier
hal-00832756 , version 1 (14-02-2020)
Raphaël Côte, Claudio Muñoz. Multi-solitons for nonlinear Klein-Gordon equations. Forum of Mathematics, Sigma, 2014, 2, pp.e15. ⟨10.1017/fms.2014.13⟩. ⟨hal-00832756⟩
210 Consultations
35 Téléchargements
