Stability issues in the quasineutral limit of the one-dimensional Vlasov-Poisson equation - Département de mathématiques Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2015
This work is concerned with the quasineutral limit of the one-dimensional Vlasov-Poisson equation, for initial data close to stationary homogeneous profiles. Our objective is threefold: first, we provide a proof of the fact that the formal limit does not hold for homogeneous profiles that satisfy the Penrose instability criterion. Second, we prove on the other hand that the limit is true for homogeneous profiles that satisfy some monotonicity condition, together with a symmetry condition. We handle the case of well-prepared as well as ill- prepared data. Last, we study a stationary boundary-value problem for the formal limit, the so-called quasineutral Vlasov equation. We show the existence of numerous stationary states, with a lot of freedom in the construction (compared to that of BGK waves for Vlasov-Poisson): this illustrates the degeneracy of the limit equation.
1311.6397.pdf (532.42 Ko) Télécharger le fichier
hal-00909196 , version 1 (11-01-2024)
Daniel Han-Kwan, Maxime Hauray. Stability issues in the quasineutral limit of the one-dimensional Vlasov-Poisson equation. 2013. ⟨hal-00909196⟩
240 Consultations
9 Téléchargements
