$ \mathcal{N} $ = 2 higher-derivative couplings from strings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of High Energy Physics Année : 2014
We consider the Calabi-Yau reduction of the Type IIA eight derivative one-loop stringy corrections focusing on the couplings of the four dimensional gravity multiplet with vector multiplets and a tensor multiplet containing the NS two-form. We obtain a variety of higher derivative invariants generalising the one-loop topological string coupling, $F_1$, controlled by the lowest order Kahler potential and two new non-topological quantities built out of the Calabi-Yau Riemann curvature.
1311.4797v1.pdf (562.73 Ko) Télécharger le fichier
cea-01310367 , version 1 (02-05-2016)
Stefanos Katmadas, Ruben Minasian. $ \mathcal{N} $ = 2 higher-derivative couplings from strings. Journal of High Energy Physics, 2014, 2014 (2), pp.093. ⟨10.1007/JHEP02(2014)093⟩. ⟨cea-01310367⟩
44 Consultations
220 Téléchargements
