Development of a 3D printed water cooled bolometric camera for long pulse operation in WEST From design to manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2019
WEST is a full tungsten (W) superconducting, water cooled tokamak, targeted at mastering long pulse operation in a metallic environment. It is equipped with two divertors at the top and bottom of the machine. As the new holding structures of the top divertor are occupying most of the space in the vertical ports, it was necessary to redesign the vertical bolometer and install it in-vessel to recover the view of the full poloidal section. We present here the solutions which were adopted to fulfill this goal.
P. Devynk - poster ECPD 2019 modif 2.pdf (466.1 Ko) Télécharger le fichier
cea-02434047 , version 1 (09-01-2020)
  • HAL Id : cea-02434047 , version 1
P. Devynck, F. Faïsse, J.M Verger. Development of a 3D printed water cooled bolometric camera for long pulse operation in WEST From design to manufacturing. 3rd European Conference on Plasma Diagnostics (ECPD), May 2019, Lisbonne, Portugal. ⟨cea-02434047⟩
45 Consultations
43 Téléchargements
