Solver comparison for Poisson-like equations on tokamak geometries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Emily Bourne
Virginie Grandgirard
Martin J Kühn
The solution of Poisson-like equations defined on complex geometry is required for gyrokinetic simulations, which are important for the modelling of plasma turbulence in nuclear fusion devices such as the ITER tokamak. In this paper, we compare three solvers capable of solving this problem, in terms of the accuracy of the solution, and their computational efficiency. The first, the Spline FEM solver, uses C 1 polar splines to construct a finite elements method which solves the equation on curvilinear coordinates. The resulting linear system is solved using a conjugate gradient method. The second, the GmgPolar solver, uses a symmetric finite differences method to discretise the differential equation. The resulting linear system is solved using a tailored geometric multigrid scheme, with a combination of zebra circle and radial line smoothers, together with an implicit extrapolation scheme. The third, the Embedded Boundary solver, uses a finite volumes method on Cartesian coordinates with an embedded boundary scheme. The resulting linear system is solved using a multigrid scheme. The Spline FEM solver is shown to be the most accurate. The GmgPolar solver is shown to use the least memory. The Embedded Boundary solver is shown to be the fastest in most cases. All three solvers are shown to be capable of solving the equation on a realistic non-analytical geometry. The Embedded Boundary solver is additionally used to attempt to solve an X-point geometry, highlighting the problems with concave boundaries.
GyselaX_comparison.pdf (3.09 Mo) Télécharger le fichier
GyselaX_comparison (1).pdf (3.09 Mo) Télécharger le fichier
cea-03786723 , version 1 (23-09-2022)
  • HAL Id : cea-03786723 , version 1
Emily Bourne, Philippe Leleux, Katharina Kormann, Carola Kruse, Virginie Grandgirard, et al.. Solver comparison for Poisson-like equations on tokamak geometries. 2022. ⟨cea-03786723⟩
175 Consultations
209 Téléchargements
