Reduced basis method for non-symmetric eigenvalue problems: application to the multigroup neutron diffusion equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this article, we propose a reduced basis method for parametrized non-symmetric eigenvalue problems arising in the loading pattern optimization of a nuclear core in neutronics. To this end, we derive a posteriori error estimates for the eigenvalue and left and right eigenvectors. The practical computation of these estimators requires the estimation of a constant called prefactor, which we can express as the spectral norm of some operator. We provide some elements of theoretical analysis which illustrate the link between the expression of the prefactor we obtain here and its well-known expression in the case of symmetric eigenvalue problems, either using the notion of numerical range of the operator, or via a perturbative analysis. Lastly, we propose a practical method in order to estimate this prefactor which yields interesting numerical results on actual test cases. We provide detailed numerical simulations on two-dimensional examples including a multigroup neutron diffusion equation.
main (1).pdf (1.17 Mo) Télécharger le fichier
cea-04156959 , version 1 (10-07-2023)
  • HAL Id : cea-04156959 , version 1
Yonah Conjungo Taumhas, Geneviève Dusson, Virginie Ehrlacher, Tony Lelièvre, François Madiot. Reduced basis method for non-symmetric eigenvalue problems: application to the multigroup neutron diffusion equations. 2023. ⟨cea-04156959⟩
121 Consultations
69 Téléchargements
