An Application of Reduced Basis Methods to Core Computation in APOLLO3 ® - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In the aim of reducing the computational cost of the resolution of parameter-dependent eigenvalue problems, a model order reduction (MOR) procedure is proposed. We focus on the case of non-self-adjoint generalized eigenvalue problems, such as the stationary multigroup neutron diffusion equations. The method lies in an approximation of the manifold of solutions using a Proper Orthogonal Decomposition approach. The numerical method is composed of two stages. In the offline stage, we build a reduced space which approximates the manifold. In the online stage, for any given new set of parameters, we solve a reduced problem on the reduced space within a much smaller computational time than the required time to solve the high-fidelity problem. This method is applied to core computations in the APOLLO3® code.
hal_preprint.pdf (533.83 Ko) Télécharger le fichier
cea-04300495 , version 1 (22-11-2023)
  • HAL Id : cea-04300495 , version 1
Yonah Conjungo Taumhas, Geneviève Dusson, Virginie Ehrlacher, Tony Lelièvre, François Madiot. An Application of Reduced Basis Methods to Core Computation in APOLLO3 ®. 2023. ⟨cea-04300495⟩
60 Consultations
31 Téléchargements
