Experimental and numerical thermal analysis for direct microwave heating of silicon carbide - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Ceramic Society Année : 2021
A comparison between experiment and numerical simulation of microwave heating of a parallelepipedic silicon carbide (SiC) sample is presented. Using a-2.45 GHz single-mode cavity, the evolution of the surface temperature is first experimentally studied for different orientations of the sample. A finite element analysis of this electromagnetic-thermal coupled problem is then conducted with the COMSOL Multiphysics ® software. Despite the different approximations of our model, a good agreement between experimental and numerical results is found, confirming that the heating of SiC depends only on the electric field. The effect of sample orientations and the cavity length on heating is also highlighted and analyzed.
Matériaux
IG_PG American Ceramic Society 2021.pdf (5.04 Mo) Télécharger le fichier
emse-03223272 , version 1 (11-04-2024)
Inès Ghorbel, Patrick Ganster, Nicolas Moulin, Christophe Meunier, Julien Bruchon. Experimental and numerical thermal analysis for direct microwave heating of silicon carbide. Journal of the American Ceramic Society, 2021, 104 (1), pp.302-312. ⟨10.1111/jace.17451⟩. ⟨emse-03223272⟩
32 Consultations
0 Téléchargements
