Optimal Control of Systems of Conservation Laws and Application to Non-Equilibrium Traffic Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Denis Jacquet
  • Fonction : Auteur
  • PersonId : 835313
Damien Koenig
This paper proposes an optimization algorithm to solve iteratively optimal control problems involving systems of conservation laws. The irregularity of their solution requires a specific variational analysis that have direct implications on the numerical implementation. This method is applied to the control of non-equilibrium traffic using the Payne-Whitham and the Aw-Rascle-Zhang model.
CAO06-Jacquet.pdf (251.95 Ko) Télécharger le fichier
hal-00098671 , version 1 (25-09-2006)
  • HAL Id : hal-00098671 , version 1
Denis Jacquet, Carlos Canudas de Wit, Damien Koenig. Optimal Control of Systems of Conservation Laws and Application to Non-Equilibrium Traffic Control. Proceedings of the 13th IFAC Workshop on Control Applications of Optimisation, 2006, -, France. pp.6. ⟨hal-00098671⟩
211 Consultations
432 Téléchargements
