A sketch-based interface for clothing virtual characters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Computer Graphics and Applications Année : 2007
We present a new method for interactively creating garments for dressing virtual characters. The user draws an outline of the front and back of the garment, and the system makes reasonable geometric inferences about the overall shape of the garment (ignoring constraints arising from physics). Both the garment's shape and the way the character is wearing it are determined at once. We use the distance from the 2D garment silhouette to the character model to infer the variations of the distance between the remainder of the garment and the character in 3D. The garment surface is generated from the silhouette and border lines and this varying distance information, using a distance field to the character's body. This method is integrated in an interactive system in which the user sketches the garment over the 3D model of the character. Our results show that the system can be used to create a broad range of clothes that may be worn in a variety of ways.
sketch.pdf (1.62 Mo) Télécharger le fichier
sketch.avi (78.34 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00171414 , version 1 (29-04-2011)
Emmanuel Turquin, Jamie Wither, Laurence Boissieux, Marie-Paule Cani, John F. Hughes. A sketch-based interface for clothing virtual characters. IEEE Computer Graphics and Applications, 2007, 27 (1), pp.72-81. ⟨10.1109/MCG.2007.1⟩. ⟨hal-00171414⟩
1401 Consultations
2212 Téléchargements
