High pressure behavior of CsC8 graphite intercalation compound - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review B: Condensed Matter and Materials Physics (1998-2015) Année : 2008
Pierre Toulemonde
J.P. Itié
  • Fonction : Auteur
A.-M. Flank
  • Fonction : Auteur
P. Lagarde
  • Fonction : Auteur
Gilles Montagnac
The high pressure phase diagram of CsC8 graphite intercalated compound has been investigated at ambient temperature up to 32 GPa. Combining X-ray and neutron diffraction, Raman and X- ray absorption spectroscopies, we report for the first time that CsC8, when pressurized, undergoes phase transitions around 2.0, 4.8 and 8 GPa. Possible candidate lattice structures and the transition mechanism involved are proposed. We show that the observed transitions involve the structural re- arrangement in the Cs sub-network while the distance between the graphitic layers is continuously reduced at least up to 8.9 GPa. Around 8 GPa, important modifications of signatures of the electronic structure measured by Raman and X-ray absorption spectroscopies evidence the onset of a new transition.
article.pdf (938.78 Ko) Télécharger le fichier
hal-00180769 , version 1 (24-10-2007)
N. Rey, Pierre Toulemonde, D. Machon, L. Duclaux, S. Le Floch, et al.. High pressure behavior of CsC8 graphite intercalation compound. Physical Review B: Condensed Matter and Materials Physics (1998-2015), 2008, 77 (12), pp.125433. ⟨10.1103/PhysRevB.77.125433⟩. ⟨hal-00180769⟩
186 Consultations
166 Téléchargements
