Storage Tradeoffs in a Collaborative Backup Service for Mobile Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
Mobile devices are increasingly relied on but are used in contexts that put them at risk of physical damage, loss or theft. We consider a fault-tolerance approach that exploits spontaneous interactions to implement a collaborative backup service. We define the constraints implied by the mobile environment, analyze how they translate into the storage layer of such a backup system and examine various design options. The paper concludes with a presentation of our prototype implementation of the storage layer, an evaluation of the impact of several compression methods, and directions for future work.
storage.final.pdf (82.53 Ko) Télécharger le fichier
hal-00187069 , version 1 (13-11-2007)
  • HAL Id : hal-00187069 , version 1
Ludovic Courtès, Marc-Olivier Killijian, David Powell. Storage Tradeoffs in a Collaborative Backup Service for Mobile Devices. 2006. ⟨hal-00187069⟩
546 Consultations
197 Téléchargements
