Blockwise processing applied to brain microvascular network study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Medical Imaging Année : 2006
The study of cerebral microvascular networks requires high-resolution images. However, to obtain statistically relevant results, a large area of the brain (several square millimeters) must be analyzed. This leads us to consider huge images, too large to be loaded and processed at once in the memory of a standard computer. To consider a large area, a compact representation of the vessels is required. The medial axis is the preferred tool for this application. To extract it, a dedicated skeletonization algorithm is proposed. Numerous approaches already exist which focus on computational efficiency. However, they all implicitly assume that the image can be completely processed in the computer memory, which is not realistic with the large images considered here. We present in this paper a skeletonization algorithm that processes data locally (in subimages) while preserving global properties (i.e., homotopy). We then show some results obtained on a mosaic of three-dimensional images acquired by confocal microscopy.
hal-00308887 , version 1 (04-08-2008)
Céline Fouard, Grégoire Malandain, Steffen Prohaska, Malte Westerhoff. Blockwise processing applied to brain microvascular network study. IEEE Transactions on Medical Imaging, 2006, 25 (10), pp.1319 - 1328. ⟨10.1109/TMI.2006.880670⟩. ⟨hal-00308887⟩
171 Consultations
0 Téléchargements
