Mixin modules in a call-by-value setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Programming Languages and Systems (TOPLAS) Année : 2005
The ML module system provides powerful parameterization facilities, but lacks the ability to split mutually recursive definitions across modules, and does not provide enough facilities for incremental programming. A promising approach to solve these issues is Ancona and Zucca's mixin modules calculus CMS. However, the straightforward way to adapt it to ML fails, because it allows arbitrary recursive definitions to appear at any time, which ML does not support. In this paper, we enrich CMS with a refined type system that controls recursive definitions through the use of dependency graphs. We then develop a separate compilation scheme, directed by dependency graphs, that translates mixin modules down to a CBV lambda-calculus extended with a non-standard let rec construct.
cmsv-long.pdf (381.93 Ko) Télécharger le fichier
hal-00310317 , version 1 (08-08-2008)
Tom Hirschowitz, Xavier Leroy. Mixin modules in a call-by-value setting. ACM Transactions on Programming Languages and Systems (TOPLAS), 2005, 27 (5), pp.857 - 881. ⟨10.1145/1086642.1086644⟩. ⟨hal-00310317⟩
182 Consultations
172 Téléchargements
