Higher-dimensional categories with finite derivation type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Yves Guiraud
Philippe Malbos
The finite derivation type property is a homotopical condition on monoids. Craig Squier has proved that a monoid must satisfy it in order to admit a presentation by a finite and convergent rewriting system. We generalise the property to n-categories presented by polygraphs and we recover Squier's theorem when n is 1. However, we prove that this result does not hold anymore for categories of dimension 2 and above. We study several examples of 2-categories presented by finite convergent polygraphs, with or without the property of finite derivation type, in order to illustrate sample cases.
ntdf.pdf (1021.8 Ko) Télécharger le fichier
hal-00326974 , version 1 (06-10-2008)
hal-00326974 , version 2 (20-10-2009)
  • HAL Id : hal-00326974 , version 1
Yves Guiraud, Philippe Malbos. Higher-dimensional categories with finite derivation type. 2008. ⟨hal-00326974v1⟩
Collections
ICJ
270 Consultations
163 Téléchargements
