Implementation and Evaluation of Shared-Memory Communication and Synchronization Operations in MPICH2 using the Nemesis Communication Subsystem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 2007
This paper presents the implementation of MPICH2 over the Nemesis communication subsystem and the evaluation of its shared-memory performance. We describe design issues as well as some of the optimization techniques we employed. We conducted a performance evaluation over shared memory using microbenchmarks. The evaluation shows that MPICH2 Nemesis has very low communication overhead, making it suitable for smaller-grained applications.
parco2k7_final.pdf (139.61 Ko) Télécharger le fichier
hal-00344327 , version 1 (04-12-2008)
Darius Buntinas, Guillaume Mercier, William Gropp. Implementation and Evaluation of Shared-Memory Communication and Synchronization Operations in MPICH2 using the Nemesis Communication Subsystem. Parallel Computing, 2007, 33 (9), pp.634-644. ⟨10.1016/j.parco.2007.06.003⟩. ⟨hal-00344327⟩
186 Consultations
298 Téléchargements
