Design and Evaluation of Nemesis: a Scalable, Low-Latency, Message-Passing Communication Subsystem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a new low-level communication subsystem called Nemesis. Nemesis has been designed and implemented to be scalable and efficient both in the intranode communication context using shared-memory and in the internode communication case using high-performance networks and is natively multimethod-enabled. Nemesis has been integrated in MPICH2 as a CH3 channel and delivers better performance than other dedicated communication channels in MPICH2. Furthermore, the resulting MPICH2 architecture outperforms other MPI implementations in point-to-point benchmarks.
Mots clés
article_ccgrid06.pdf (130.15 Ko) Télécharger le fichier
hal-00344350 , version 1 (04-12-2008)
Darius Buntinas, Guillaume Mercier, William Gropp. Design and Evaluation of Nemesis: a Scalable, Low-Latency, Message-Passing Communication Subsystem. Sixth IEEE International Symposium on Cluster Computing and the Grid (CCGRID'06), May 2006, Singapour, Singapore. pp.521-530, ⟨10.1109/CCGRID.2006.31⟩. ⟨hal-00344350⟩
93 Consultations
194 Téléchargements
