Chebyshev Knots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Chebyshev Knots
A Chebyshev knot is a knot which admits a parametrization of the form $ x(t)=T_a(t); \ y(t)=T_b(t) ; \ z(t)= T_c(t + \phi), $ where $a,b,c$ are pairwise coprime, $T_n(t)$ is the Chebyshev polynomial of degree $n,$ and $\phi \in \RR .$ Chebyshev knots are non compact analogues of the classical Lissajous knots. We show that there are infinitely many Chebyshev knots with $\phi = 0.$ We also show that every knot is a Chebyshev knot.
cheb8-4.pdf (1.18 Mo) Télécharger le fichier
hal-00344501 , version 1 (04-12-2008)
hal-00344501 , version 2 (08-04-2010)
Pierre-Vincent Koseleff, Daniel Pecker. Chebyshev Knots. 2008. ⟨hal-00344501v1⟩
246 Consultations
392 Téléchargements
