A Branch-and-Bound Procedure to Minimize Total Tardiness on One Machine with Arbitrary Release Dates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2004
In this paper, we present a Branch-and-Bound procedure to minimize total tardiness on one machine with arbitrary release dates. We introduce new lower bounds and we generalize some well-known dominance properties. Our procedure handles instances as large as 500 jobs although some 60 jobs instances remain open. Computational results show that the proposed approach outperforms the best known procedures.
1_ri_sumTi.pdf (184.32 Ko) Télécharger le fichier
hal-00357955 , version 1 (02-02-2009)
Philippe Baptiste, Jacques Carlier, Antoine Jouglet. A Branch-and-Bound Procedure to Minimize Total Tardiness on One Machine with Arbitrary Release Dates. European Journal of Operational Research, 2004, 158 (3), pp.595-608. ⟨10.1016/S0377-2217(03)00378-3⟩. ⟨hal-00357955⟩
231 Consultations
534 Téléchargements
