High resolution X-ray tomography of micromechanisms of fatigue crack closure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scripta Materialia Année : 2006
Fatigue crack closure has been studied in an aluminium alloy via microtomography. Gallium wetting has been used to visualise grain structure, along with electron backscattered diffraction assessment of grain orientations and crack trajectories. Through this synthesis of techniques, a detailed direct assessment of microstructure and closure micromechanisms has been achieved.
Khor2006.pdf (402.67 Ko) Télécharger le fichier
hal-00436213 , version 1 (23-04-2024)
Kern Hauw Khor, Jean-Yves Buffiere, Wolfgang Ludwig, Ian Sinclair. High resolution X-ray tomography of micromechanisms of fatigue crack closure. Scripta Materialia, 2006, 55 (1), pp.47-50. ⟨10.1016/j.scriptamat.2006.01.016⟩. ⟨hal-00436213⟩
15 Consultations
0 Téléchargements
