Random sampling of lattice paths with constraints, via transportation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
Lucas Gerin
  • Fonction : Auteur
  • PersonId : 835101
We discuss a Monte Carlo Markov Chain (MCMC) procedure for the random sampling of some one-dimensional lattice paths with constraints, for various constraints. We show that an approach inspired by optimal transport allows us to bound efficiently the mixing time of the associated Markov chain. The algorithm is robust and easy to implement, and samples an "almost" uniform path of length $n$ in $n^{3+\eps}$ steps. This bound makes use of a certain contraction property of the Markov chain, and is also used to derive a bound for the running time of Propp-Wilson's CFTP algorithm.
LatticePathsWeb.pdf (169.51 Ko) Télécharger le fichier
hal-00439479 , version 1 (07-12-2009)
hal-00439479 , version 2 (05-02-2010)
hal-00439479 , version 3 (08-06-2010)
hal-00439479 , version 4 (20-08-2015)
  • HAL Id : hal-00439479 , version 1
Lucas Gerin. Random sampling of lattice paths with constraints, via transportation. 2009. ⟨hal-00439479v1⟩
155 Consultations
722 Téléchargements
