Fast orthogonal sparse approximation algorithms over local dictionaries
Boris Mailhé 1 Rémi Gribonval 1 Pierre Vandergheynst 2 Frédéric Bimbot 1
1 METISS - Speech and sound data modeling and processing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : In this work we present a new greedy algorithm for sparse approximation called LocOMP. LocOMP is meant to be run on local dictionaries made of atoms with much shorter supports than the signal length. This notably encompasses shift-invariant dictionaries and time-frequency dictionaries, be they monoscale or multiscale. In this case, very fast implementations of Matching Pursuit are already available. LocOMP is almost as fast as Matching Pursuit while approaching the signal almost as well as the much slower Orthogonal Matching Pursuit.
Liste complète des métadonnées
Littérature citée [12 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-00460558
Contributeur : Boris Mailhé <>
Soumis le : mardi 26 avril 2011 - 11:39:51
Dernière modification le : vendredi 16 novembre 2018 - 01:25:05
Document(s) archivé(s) le : mercredi 27 juillet 2011 - 02:35:25
Fichier
LocOMP.pdf
Fichiers produits par l'(les) auteur(s)
Citation
Boris Mailhé, Rémi Gribonval, Pierre Vandergheynst, Frédéric Bimbot. Fast orthogonal sparse approximation algorithms over local dictionaries. Signal Processing, Elsevier, 2011, 〈http://www.sciencedirect.com/science/article/B6V18-51WV00K-3/2/ea5d3613cf553f760064299db3c0f5cd〉. 〈10.1016/j.sigpro.2011.01.004〉. 〈hal-00460558v3〉
Métriques
Consultations de la notice
689
Téléchargements de fichiers
273
