A numerical algorithm coupling a bifurcating indicator and a direct method for the computation of Hopf bifurcation points in fluid mechanics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Fluids Année : 2010
This paper deals with the computation of Hopf bifurcation points in fluid mechanics. This computation is done by coupling a bifurcation indicator proposed recently and a direct method which consists in solving an augmented system whose solutions are Hopf bifurcation points. The bifurcation indicator gives initial critical values (Reynolds number, Strouhal frequency) for the direct method iterations. Some classical numerical examples from fluid mechanics, in two dimensions, are studied to demonstrate the efficiency and the reliability of such an algorithm.
brezillon2010.pdf (1.6 Mo) Télécharger le fichier
hal-00493902 , version 1 (21-06-2018)
Anthony Brézillon, Grégory Girault, Jean-Marc Cadou. A numerical algorithm coupling a bifurcating indicator and a direct method for the computation of Hopf bifurcation points in fluid mechanics. Computers and Fluids, 2010, 39 (7), pp.1226-1240. ⟨10.1016/j.compfluid.2010.03.006⟩. ⟨hal-00493902⟩
105 Consultations
111 Téléchargements
