Doppler Estimation and Data detection for Underwater Acoustic ZF-OFDM Receiver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new scheme for Doppler estimation and data detection for OFDM underwater acoustic communications is derived in this paper. We design the OFDM symbol as a concatenation of two sub-blocks. The first one is shorter and carries out few data with few subcarriers whereas the second one contains both informative and pilot symbols. The first sub-block serves to estimate the Doppler scaling factor while the pilots in the second sub-block are used for estimating the equivalent channel. Both estimation approaches are based on high resolution methods for solving harmonic retrieval problems in time and frequency domains respectively. Each sub-block contains a cyclic suffix, which allows having more data to be processed. The effectiveness of the proposed scheme is evaluated by means of simulation results.
Kibangou_ISWCS_10_final.pdf (154.55 Ko) Télécharger le fichier
hal-00498161 , version 1 (06-07-2010)
  • HAL Id : hal-00498161 , version 1
Alain Kibangou, Laurent Ros, Cyrille Siclet. Doppler Estimation and Data detection for Underwater Acoustic ZF-OFDM Receiver. ISWCS 2010 - 7th International Symposium on Wireless Communication Systems, Sep 2010, York, United Kingdom. pp.n.c. ⟨hal-00498161⟩
309 Consultations
289 Téléchargements
